Camera connected to the wrong base station. Easier way than deleting camera and adding?
  • 1 Reply
  • 1132 Views
Savinderm
Hello Arlo Community!  I currently run two baes stations and eight cameras in our home to cover the entire property.  An East and West base station if you will.  One of my cameras is connected to the further base station and would benefit from being paired to the closer station to improve signal strength.  I can not find a way to make the change.  Is there an easier way that deleting the camera and trying to add to the correct base station.  I’m trying to avoid climbing on ladders.  🙂
thanks you for any and all advice
No...not an easy way.
You must delete the camera from the far base ( remove device ) and then sync it to the close base
