Camera can't be added
The camera may be giving up the ghost but first, there are several things you can try. Firstly, try removing the power from the base for a couple of minutes then powering it back up. allowing the base and cameras to correct any corrupted firmware. Secondly, I have had instances where the cameras culd not be found by using the app although you do not need the app to sync the cameras. You could simply briefly press the sync button on the base followed by briefly pressing the sync button on the camera. As a last resort, you can remove all the devices from your account and do a factory reset then add everything back.
Good luck,
Brian
Thanks Brian! I've tried the first suggestion, but still no connection. The camera blue light keeps flashing. I'll try the second one, but hope both base and existing added camera will reconnect. BTW, what do you mean by "the camera may be giving up the ghost..."?
Sorry, I mean that after three or four years, the camera may be dying. I believe you said that you were using the original cameras. There can be issues with the battery connections. Two things - firstly, carefully be sure that the battery contacts in the camera are clean and have not been pushed down, and secondly, drop the batteries in then let the pressure of the closing of the battery cover exert the correct amount of pressure on the batteries, ( batteries from different manufacturers vary in height and thickness).
Brian
