ARLO HD Camera
Hi people, I have noticed that there is a USB port on the camera. Can i remove the 4 batteries and plug in a 5 V USB power pack instead?
Arlo Wire-free HD Camera Security System
The original Arlo Wire-free cameras were not designed to be powered through the micro-usb port or any other means. Doing so could damage the camera and void the warranty.
I encourage you to review Remember these golden rules for your Arlo camera batteries along with BATTERY WARNINGS AND SAFETY.
Some folks have tried but the voltage from USB is too low for it to be reliable. The batteries provide 6+ volts.
Ok cool, thank you. I wonder if I can feed 6 volts directly to one pair (+ -) terminals, and will work ok?
No , you have to use both sets as properly setup with cells, with same voltage
Why not just use the Tenergy rechargeable 3.7 V batteries (or others that have been shown to work). Saves having o buy batteries and keeps your warranty valid.
Do u know why there are 2 X 6 volt banks?
Can I parallel the 2 X 6 volt sides together?
Thank you
Steve
The design of two banks of 6v batteries is to alternate which sets are in use to maximize battery life. I don't know the algorithm but you can run off one set of two batteries - you'll just see 50% battery capacity when doing so. If you were to parallel the connections between the two sets, you'd see 100%.
Ok thank you for your help, much appreciated,
Ill bet that would do yhe trick as well.
