  • 1 Reply
  • 1858 Views
Rtort
Is there a limit to the number of videos stored in one day on the 7 day free plan? It seems like I recorded 47 videos one day but there should be more for that day. I still have videos from the previous 6 days so storage doesn't seem to be an issue, just number that day. Anyone can help explain?
There shouldn't be.
One thing you can try is adding USB storage to the base (assuming a VMB4xxx) and set up local recording.
Then you can look at the USB storage, and see if anything is missing.  (Note that with VMB4000 and VMB4500 you will need to eject the storage and put it in a PC to check it).
