i dont have anything to plug ethernet to can i run this off of my hotspot
Use a WiFi extender that is connected to your hotspot. Then use the Ethernet cable from the base to connect to the extender.
I dont have an extender either I guess I will just return it to the store. Thanks for trying to help
WiFi extenders are cheap.
