Bug??
Found out putting a flash disk or HD in the Router R7000 USB ports makes the Arlo Camera stop working and Arlo Page message "no device found".
I was putting a new flash disk (Sandisk) to the R7000 USB port and the R7000 page froze up, got a blank page, I had to switch off the router and start it again, and found Arlo Page message "no device found" & Arlo site got "Camera offline" message.
I had to remove flash disk and reset the Router to make the camera work again.
Sal
Sa9aX11,
I have escalated your post for further investigation.
Thank you,
JamesC wrote:Sa9aX11,
Thank you,
Thanks.
It just useless those USB ports when I have Arlo Camera active, I want put a flash disk so I can share files (24 hrs a day) and also use the Netgear downloader.
Why doesn't the Netgear Downloader use the ReadyNas device?
Sal
