Brightness
Hi, can I adjust the brightness of a video in the library ie once it has recorded. If not can I set a brightness adjustment for daytime and then a different one for nightvision. I have a particular external cam that needs to be on full brightness at nighttime and half brightness in the daytime, any advice?
You can't set the brightness individually for day and night - only one setting. It depends on what's most important but generally these small sensors are worse at night so brightening that would be your best bet. You can use software after downloading any videos to change brightness if needed.
