Has anyone been able to fix this issue? I bought a four camera system and set it up. Nice and easy I might say but one of the cameras refuses to stay online. It's number 3 in my set up. Done all the things I can see on this forum. Nada. Not happy after spending $550.00.
Raish58 wrote:Has anyone been able to fix this issue? I bought a four camera system and set it up. Nice and easy I might say but one of the cameras refuses to stay online. It's number 3 in my set up. Done all the things I can see on this forum. Nada. Not happy after spending $550.00.
I would try swapping two cameras... One that works to the location of the one that doesn't to see if its the camera or location/interference.
If the problem follows the camera, then do a reset of the camera by opening the battery door for about 3 secs then reclose. After it sync's if the problem continues with the same camera, then it's a possiblitly the cam has a defect and you should contact netgear for a replacement.
I have the same issue. I have swapped cameras around with the same camera still going 'offline'... Power reset, re-sync, no change...
Trouble ticket time...
Turtl,
Welcome to the community! I would add that you may consider replacing the batteries in the affected camera with a fresh set. If you have followed the above troubleshooting steps and still are getting the same results isolated to a single camera, like @jguerdat I encourage you to contact our support team for further validation of potential RMA.
Let us know the results!
