Blurry video feed
When I receive a notice and log on to view the video, the video feed is blurry. When I then click the "live" button to see a live feed it, too, is blurry or it only shows half the screen.
I live in Leawood, KS and the temps this time of year are around 20 degrees. Is the cold weather having an effect on my camera? I have another camera placed under a deck to view a basement door and this camera is just fine.
adammolinaro,
Could you post a screenshot of the blurry image? It sounds like it could be condensation on the outside of the camera. One way to further isolate the issue would be to swap locations with the unaffected camera and see if you get the same results.
You do understand that 720p is less than 1 megapixel, right? Zooming in is limited just for starters. Add in compression and it can get worse. I suspect that if you compare with other systems you'll find similar results.
