Thank you so much!
My App did same thing and my cameras do not record and motion set to arm and not working is yours?
I powered my phone off for 5 min then powered it back on then it worked ok. Seams like everthing is working now
good to hear it's working... the usu fix is to re-install app as you did.
I have the same issue with my Android Tablet. The Android app on my Samsung cell just keeps giving me a "App has stopped" message. I determined the problems went away when I had my daughter remove my email from her Arlo account which gave me access to see her cameras. After a day or so of all working OK, I got the same problem. She again took me off her account and things started working on my end just fine. Seems to have something to do with being granted access to a different Arlo router.
I would send a text to Netgear support... may be another bug. ( they can't fix unless they know )
