What is the best rechargeable battery for Arlo? I got my unit yesterday and the battery shows as 76%. I dont want to spend a fortune on batteries. Thanks
This is in the PRO section and the title says the same....
For the PRO at this time there is ONLY one battery available.
For the regular Arlo , there are 60+ pages of info on rechargable batteries, read at least the last 10-15 pages for the info you'll need
OR
Wait a short while as Netgear is coming out with an approved batteries set and charge system for the Arlos.
I got the VMB3000. Not sure if that is the pro. Will netgear recommend a rechargeable battery unit for it?
The 3000 is actually the Arlo base I believe ... So you mean the regular Arlo camera.
Yes , it has been announced that soon they will release approved rechargeables for that camera
The Arlo does have rechargeable batteries available for the original Arlo.
Amazon.com Associates Central - Home
Those are the only batteries approved ny NETGEAR currently I believe.
