Not sure about what's the best camera, but IMO don't waste your money on the Arlo lights. If you **reeeeally** need an additional, non-camera device to use as a trigger for your cameras, then yes they work for that. But they're virtually useless for extending the camera's range at night. If that's what you want, get a dedicated, motion-sensing IR illuminator. From a purely lighting perspective, for example you just want to light up your door entry area when someone approaches, they're no better than motion-sensing LED lights you can get from Amazon for less than $30.
Personally I'd say the Ultra is better.
Ultra
- has max 180 degree field of view
- has 4K resultoin
- connects at both 2.4 ghz and 5 ghz
- has wind noise reduction for audio
- IMO has somewhat better color
Pro 3
- has max 160 degree field of view
- has 2k resolution
- no audio noise reduction
- connects at only 2.4 ghz.
That's funny, I'm pretty hard on Arlo on these forums but the Lights for me have been the best purchase. I use them as motion extenders since my cameras have good coverage for recording but are sometimes a bit far from where I want motion detected.
I'm running 3 of the lights and unlike all the issues with camera quality, lag, etc., the lights have pretty much just "worked".
For lights and cameras, I highly suggest getting some of the silicone covers available. Got mine on Amazon and I think they really help protect from UV rays and fine dust particles. Not to mention any rain.
