  • 2330 Views
Druidm299
To be able to batch delete all videos in the library with a select option. Really laborious deleting one video at a time on a given day.
You can already do this.
Are you using the Android app, the IOS app, or the web client?
Druidm299
Both Android & Web.
On the web, there is a select control on the upper right of the library.  Click it, and you'll see a select all control right next to it, and some batch options on the bottom (including delete).  When in the select mode you can also select or unselect individual files by clicking on them.  Then click delete.
In Android, you select one video in the library by touching it.  You will then see a square with 4 small solid green squares immediately next to the vertical ... at the top.  Touch that to select all.  Touch to icon immediately to the left of that to deselect all.  You can select or unselect individual files by touching them.  Then touch the trashcan to delete.
