Battery indicator says 100%, but I know it's not? Is there a fix?
  • 5 Replies
  • 3446 Views
Barry01
5 REPLIES 5
A little detail would help. How do you know it's not? Have you opened and closed the battery door to reset the camera? Did you power cycle the base?
Barry01
Hi jguerdat - Thanks for the quick reply - I know because they have been in use for a couple of months and been showing drain previous to now showing 100%
I have not tried anything yet, waiting for advice.
I suggested a couple of things above.
Barry01
OK Tried both resetting the camera and the base station and the battery indicator on one of the cameras is still reporting 100%?
Swap the batteries between cameras. If the issue remains with the camera, contact support to open a case.
