5 REPLIES 5
A little detail would help. How do you know it's not? Have you opened and closed the battery door to reset the camera? Did you power cycle the base?
Hi jguerdat - Thanks for the quick reply - I know because they have been in use for a couple of months and been showing drain previous to now showing 100%
I have not tried anything yet, waiting for advice.
I suggested a couple of things above.
OK Tried both resetting the camera and the base station and the battery indicator on one of the cameras is still reporting 100%?
Swap the batteries between cameras. If the issue remains with the camera, contact support to open a case.
