Battery drain after firmware update 11/2/2020
  • 2 Replies
  • 1630 Views
J_J_D
After firmware update yesterday, batteries went from full to 0  in 24 hours and cameras are now offline. I have reset base remotely and no changes. The system is 2.5 hours away. Is there a fix?
J_J_D
Update - After re-setting the base  multiple times and several days later, all the cameras are working and  with the same battery strength before the update. Miraculous....
ShayneS
HI @J_J_D
Please contact the Support Team to further investigate this issue with your cameras & base station. You will find several options for contacting support in the provided link. Arlo Tech Support
J_J_D
