One of the cameras' battery is always depleting faster than the other.
It will only last for few days, less than a week.
Both cameras' battery are changed at the same time.
Arlo team pls advice.
swap out the two cams and see if the depletion stays with location or cam.
The most common cause of faster unexplained depletion is poor wifi signal between cam and base station, battery depleting as the cam continually tries to stay linked to the base station
Thank you for the advice.
Had tried.
Placed both cameras at the same location. Still that one camera depletes faster and real fast.
clean the battery contacts. And when putting in cam dont push down but let closing the battery door seat them.
The 4 batteries are actually 2x2 parallel sets, so if in your case one battery isn't making proper contact, the remaing two would be only ones working so would deplete faster
The battery issue still unsolved.
Adding to this, the camera will go offline often. Meaning my app will show that camera to be offline.
Anyone pls help me..
DaveSeah,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I have exactly the same problem and have spent a fortune on replacing batteries for this one Arlo camera. Calling support does not help because the tech always has me replace the batteries and, of course, the camera works for a couple of days and the tech thinks he has solved the problem. But the problem remains - rapid depletion of the batteries. Have tried every possible solution and wish Arlo would just replace the defective camera with one that is functional.
drtank,
Have you tried swapping locations with a camera that is behaving normally to see if there is a problem at the cameras location that is causing the battery drain or if the issue follows the camera?
Hello, James.
I am trying your suggestion right now. A half hour ago I replaced the depleted batteries with new ones and located the camera 20 feet closer to the access point. I’ll let you know how the experiment goes. In all candor, though, I think the problem is a less-than-standard-quality, or defective, Arlo camera, because the camera worked fine in its original location for several weeks and then just started eating batteries and dying every 2 or 3 days. The other camera that was paired with it in the kit is starting to do the same thing. These two are not nearly as reliable and trouble-free as the original three Arlo cameras that I purchased about two and a half years ago. Those gems are still rolling along with only infrequent battery changes needed – and two of the three are located farther from the access point than the two new ones.
I appreciate your help.
drtank
Following up on my earlier response to James: I changed the location of the camera after installing the sixth set of fresh batteries in the last three months or so. The camera worked for about a day and then began consistently displaying "not connected to the internet" messages, even as my other Arlo cameras of the same model were working fine. I then brought the problem camera into my house and placed it within seven feet of the access point. Still, it was displaying a not-connected-to-the-internet message. About three days later, its new batteries were completely drained. This is a defective Arlo camera. The only question that remains is whether Netgear will perform on its advertised warranty.
Or you need to open a case with support. If it's a hardware issue, you can't solve it by posting here. Use the 1 year warranty.
Following up in conversation with James, I was not able to solve problem through attempting all humanly conceivable tactics, most at least 2 or 3 times. I did chat online with a helpful Netgear tech, and he put me through some exercises with the camera again. Finally, he agreed to replace the defective camera. I followed the e-mailed instructions to initiate the RMA process, and the replacement camera arrived today. I will be sending the defective unit to Netgear on Monday. I have not tested the replacement camera yet but have no reason to doubt that it will work satistactorily, as most Netgear products do, most of the time. Thank you for your kind suggestions and interest in my problem with the Arlo device.
cam33,
