Battery Issues- ONE camera only
  • 1 Reply
  • 2943 Views
SandraKSS
How can I tell if the camer has a short in it?  I installed three camera's, and ordered two more.  "Float camera" battery died within 3 weeks.  All camera's are set up identically with all distance being very close to the same.  Float camera does get moved around a bit (hence its name), BUT- never past the range of the others...  The second set of batteries installed into Float camera have again died.  They were in for about 3 weeks, again.  So- I think that camera has an issue.  Please tell me how I can get it checked.  Thanks
An easy test would be to swap the 'float camera' with another and see if the problem follows the camera. 3 weeks is much to short unless excessive recordings, bad range, or defective.    Distance by itself is not a determining factor and walls/mirrors/basic building materials can limit wifi signals.
You could also contact Netgear and put in a trouble ticket..they will assist in seeing if defective.
