Battery Drain Arlo Wireless Camera
  • 1572 Views
Brad99
Does having motion detection on when a camera is switched off increase battery drain for that camera.  In other words, is motion detection turned off automatically for a particular camera when the camera is switched off?  Thanks.
There is TURNING OFF the camera in settings... this is more for a privacy issue ( like a bedroom, esp if sharing )
There is the DISARM mode... It puts the cam to sleep.
Both still use almost no power
Brad99
The only place I see for turning on the disarm mode is in the settings for the base station.  Is there a way to disarm individual cameras?  Thanks.
You can either use Settings, My Devices, your camera, On/Off to use the privacy switch for individual cameras or create a custom mode if you're going to need this on a regular basis. You can then schedule the mode, too.
