  • 4487 Views
Jessef
I have replaced batteries in all four of my cameras, but two of the cameras are not recognizing new batteries. I have swapped the batteries in to other working cameras, to confirm not bad batteries.
The battery indicator on my devices for these two particular cameras are showing drained and needing battery swap. What do i do to get this fixed or replaced?
please advise and Thank you for your time!
manfredz
Hero
Hero
First thing I would confirm is that the batteries are being put in right; second is that the springs aren't stuck down, to prevent top and bottoms contacts being made.
Jessef
Thank you. I will double check springs and I appreciate your response. Is there a servie center for arlo cameras, that anyone may know of?
If a problem with cameras, the warranty is 1 yr ( tbmk )...contact Netgear Support at botton of page
