couple of questions: rechargeable or non-rechargeable batteries
how many recordings of which length were made from each cam? were also live view times?
in general I find the first day or two the drain is faster than after that
also if there is distance or barriers between base station and cams can result in battery drain as the cams use power to constantly try reconnecting to base station.
and of course could be bad batteries or one not placed right. the batteries operate as 2x2 in parallel, but if one pair wasnt placed right , only 50% would show from fresh batteries
you didn't mention of using rechargeable or non rechargeable batteries.
but either way shouldnt show that drain from that little use. be interesting to know if continues to drain at this rate.
MDE27,
Are you still seeing the battery drain at this rate? What is the signal stength for the camera like?
