Birl,
Many users have had success resolving this issue by checking their mobile devices battery saving settings. Some devices have battery optimization settings that close or put apps to sleep after they have been idle for a period of time. Check your mobile devices settings and be sure that an exception is made for Arlo if you are running battery saving settings.
Have you tried a simple power button reboot of the base?
What phone and OS ?
As to the app, you would have to check the settings of the app itself in the phone... background update allowed ?
It would be worth trying a browser to help identify an app issue.
Edit: I guess you're using geofencing so a browser won't be useful.
I run an S7 / os 7 ...the only time I see this now and then is when the phone auto logs over to my wifi and drops the LTE... some time it can't decide during the switch and will say your not on wifi network... sorta pause but I just restart it or have learned to wait till the phone says it has switched
Birl,
