Hello All,
I am trying to find out what the latest firmware version is for my basestation. The latest version showing in the device info is: 1.8.1.1-10234 is that the latest version?
Thank you.
https://community.netgear.com/t5/Firmware-Release-Notes/bd-p/arlo-release-notes
Thank you!
It looks like my base station has not updated its firmware. Could you please tell me how to do this since it did not update automatically? I have had it turned off and rebooted, etc a few weeks ago, when we upgraded our router. Looks like it would have updated then. I do not have any problems with the cameras or accessing the cameras, but I did notice that there have been no updates in the firmware.
Thank you.
No real way to 'force' an upgrade of SW... best and normal thing to do is Power button reboot the base and check the next day ( as the updates come at night )
Will do, thank you!
Katchmcg,
The latest base station firmware for the Arlo Wire-free base station is 1.8.1.1_10234. If your base station is running the firmware you indicate in your original post, you are up to date.
Looks like mine just updated to 1.8.9.0_11528
10234 here, maybe an update will upload overnight tonight?
I restarted my base then it updated..
