I bought a refurbished net gear VMS3530-100NAR Arlo Smart Home 5 HD camera security system.I'm Both the Power LED and Internet LED are solid green. I only have one Internet which is ATT. My phone is an android. I tried the reset with a paper clip and holding down the sync button. Nothing seemed to happen the camera LED light came on briefly. This is frustrating and is taking too long. Can you help?
You're using the old reset procedure. Use only the reset button until the LEDs flash amber. However, the problem may well not be yours since the system may not have been released by the previous owner. You will probably need to use the Contact Support link at the bottom here to get Netgear to release the base so your account can claim it.
the leds are POWER-INTERNET-CAMERA ( from the left )
the first two must be green first... then ( most common error is holding to long ) a QUICK push on the base sync button and a sec or two later the push on the camera button
