  • 2604 Views
pequod
My base station's sync button doesn't do anything at all, and I've already reset it multiple times, unpluged it, etc.  I have 8 other cameras already connected and I'm using the elite subscription, not sure what else I can do at this point. Please help
Explain what you mean. Pressing the sync button doesn't cause the camera LED to flash?  Are you pressing only briefly (<1 second) or holding it down?  Don't do the latter - it won't work.
pequod
Yes, the sync light doesn't blink, it just stays solid. I've tried both, multiple times.
Can you feel a click when pressing?  I suspect you have a hardware issue. You may want to exchange the system at the store or contact support using the Support link at the top here to open a case for more help and a possible RMA.
