Base Station is not discoverable
  • 1 Reply
  • 5714 Views
TTon
Bought refurbished 5 camera Arlo system from Amazon more than 1 mo ago.  Setting up was smooth except 1 camera required several resets.
System worked fine until 3 days ago, cannot see any picture from computer and smart phone. Base station: 3 green lights,  Cameras baterries 1 mo old, status 95% full 1 week ago
I have read trouble shooting from Arlo community and performed the following.
I go to my arlo account-  setting -  my device   : nothing showed up      Base station has 3 green lights on left.  Subsciption  Camera  supported 5,
connected 0    Base Station not discoverable
I clicked add device -  click base station -  nothing changed
I turned off base station,  router,  rehook back the computer and base station  to the netgear router and do factory resetting ( took longer than described in instruction)  nothing changed.  The base station still not discoverable on computer or phone,  it continues to have 3 green lights (home internet works fine)
Tried to resync 2 cameras as instructed but nothing seen
Please help
Thomas
How exactly did you perform the reset? You need to hold the button until the LEDs flash amber - don't use the sync button. Then remove all devices in Settings, My Devices and start fresh. Any luck?
