Audible 'click' with Arlo Cameras
Hello,
I have the regular Arlo base station and cameras. They have always had an audible 'click' that sounds like the opening of a camera lens (which is probably what it is) when the cameras are turned on. I find this pretty bothersome and it serves as a constant reminder to people that they're on camera. Is there a way to de-activate this?
Similarly, do you know if the new versions of Arlo (either the Pro or Pro2) have a similar noise when the camera is started?
Many thanks for your time.
I believe it's the IR filter being moved into the default position. That filter is engaged with Nightvision.
There's no way to change it.
The noise has never bothered me - so I don't know if it's quieter on the newer cameras. Are your cameras indoors?
