I have two arlos and three arlo q's The arlos will not go onlline. Both have been offline for 10 days. I have rebooted the router and the cameras I have replaced the batteries. Thoughts?
Have you re-synced them
if re synking them is pushing the button on top, yes
You also have to briefly pressing the sync button on the base, too, before the sync button on the camera.
cclarkson,
You might also consider installing a fresh set of batteries as this could be an indicator that the batteries are depleted. What is the behavior of the camera LED when you press the sync button?
