Arlo with supplemental infrared lighting to enhance night vision
Has any user tried using an external infrared LED light to enhance the range of the night vision of the camera? I was thinking about putting up an IR "spotlight" for night-time use to illuminate my driveway ...curious to know if anyone has tried this before and had positive (or negative) results.
just guessing here but you might find that the external IR may constantly set the cam off. But interesting idea and am curious if anyone who has tried can supply feedback.
I used and still do now and then use the Flood light from Vuezone that is IR at 850nm..... it is not motion activated but stays on
Any IR in that range should work for you
It has a built in day/night sensor and just about covers 4-5x time the area of the ones in the camera ( see below )
Just remember, you may want a flood over a spot light as the distance of a spot may be more than the sense level of the PIR... sort of wasted ir lighting
Acording to the Lifx site, their inbuilt IR operates a 950nm wavelength, but I believe the Arlo cameras use 850nm so the lifx lights are not compatible with Arlo's night vision capabilities. That's probably why you're not seeing anything.
