While latency could be an issue, it could be more basic. First, try resetting the base using the reset button until the LEDs flash amber. Wait for the base to reboot and see if anything changes. If not, something is blocking the connection to the servers. One thing to try is to use http://speedtest.net to check latency and upload speeds. That's useful information even if it doesn't actually solve the problem.
Who owns the networking equipment - you or the ISP? You may well need to contact the ISP for technical help. In particular, ports 80, 443 and 123 need to be open to arlo.netgear.com.
