  • 8 Replies
  • 3716 Views
  • 5 In Conversation
mdalmuld
Dear Arlo Community,
Hopefully someone can help with the following. I have an Arlo base station (VMB3000) with three Arlo wireless cameras. The cameras won't sync to the base station after I got a new modem/router. When I press the sync button on the base station, the sync status light on the base station starts blinking, but when I press the sync button on any of the cameras there is no blue sync light coming on. None of the three cameras is syncing with the base station.
I have tried the following so far:
  • I have power cycled the base station (about 10+ times now)
  • I have factory reset the base station (multiple times)
  • There are brand new batteries in all cameras. I have checked they are positioned correctly
  • I have removed all cameras from the Arlo app so I could start from scratch
  • The power and internet lights on the base station are solid green
  • I am holding the cameras less than 1 foot from the base station when attempting to sync
  • My modem/router recognises the Arlo base station - I can clearly see it listed as one of the connected devices
Any further suggestions anyone? Note that the issue happened after I installed a new modem/router. The modem/router is working fine: I have internet access and have successfully connected many other wired and wireless devices.
Thanks,
mdalmuld
8 REPLIES 8
The only thing I can think of is to move the base unit farther away from the new router...and the try and sync a camera. It may be causing some sort of interference
mdalmuld
Thanks very much for your recommendation, but unfortunately that doesn't resolve the issue.
mdalmuld,
Do you see any LED behavior on the cameras when opening and closing the battery compartment door on the camera?
mdalmuld
Hello JamesC,
No, I don't see any LED behaviour at all on the cameras. I have three cameras, but there is no LED behaviour when opening and closing the compartment doors.
Thanks,
mdalmuld
That implies dead batteries but doesn't exclude other possibilities. Have you opened a case with support here?
jes70s12
Good luck as ARLO doesn't support their products after one year warranty runs out. I have one of my 4 cameras that won't sync as well. Tried various solutions but still nothing. Contacted support and after acknowledging camera is faulty won't replace it. If I was you, go with another brand that is reliable and supports their product or you will be out a lot of money in the long run.
mdalmuld
Thanks,
That doesn't sound promising... I have three cameras that won't sync 😞
Kind regards,
Marc
mdalmuld
Thanks,
I will open a case with Support...
Kind regards,
Marc
