Arlo wireless security system vas 3230
I have 5 camers can I add any more to 1 base had problems when I added 3rd and 4th ?
pushed button on base station flashed, pushed button on camera flash blue for 12 seconds then flashed Amber can't connect ?
Not on the basic (free) plan. Five cameras is the maximum, and it's not per base station, but per account.
You have two options: either upgrade to a paid plan (and connect your sixth camera to the existing base station) or buy a second base station and add your sixth camera to the second base station on a new account. You could keep both accounts on the basic plan though, so no subscription fee necessary. Problem is though that as far as I know you can't buy a base station without at least one camera. Also, it's more of a hassle to flip-flop between two accounts, since you'll have to manually enter the user ID and password every time you switch.
