Arlo wireless not detecting motion anymore. Batteries are fully charged and sensitivity 100%.
My cameras have worked fine in the past, up until about two weeks ago and they are not detecting anything anymore. The batteries are fully charged, I have up the sensitivity to the detection, I have made sure it's on armed for the mode. I have also restarted the base, disconnected and reconnected the cameras. The only time they work is when I do it manually.
Hey Asmileforme2u,
Have you tried using the motion detection test to see if your camera detects motion? You can read here to learn how to use the test: How do I use the motion detection test for my Arlo device?
Make sure that your camera is not too far from the Base Station to make sure it will detect motion and to ensure a stable connection. Otherwise, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
