Could be - what versions show in Settings, My Devices?
You posted this last night and updates normally occur overnight. Are things working better today? If not, a reset may help. Use the reset button on the base until the LEDs flash amber. Remove all devices in Settings, My Devices. When the base has rebooted with two green LEDs (power and Internet), use the Add Device button on the Devices tab to add the base and then sync the cameras.
