  • 3276 Views
jkmail
I am not receiving any emails again when there is motion and camera is not recording and posting in library. Are the servers down ?? What's  going on .
Maybe it's not enough motion to record? I'm not having issues. Are the running men black?
jkmail
It started working on 2 of them this evening . I'll check later.
The last camera that I had replaced under Warranty had not . I noticed too that it doesn't show last picture seen any time like the others do , just all green until you click on live.
The usual recommendation to fix the green screen is to remove the camera in Settings and then re-sync it.  Does that fix it?
