ginnsinn,
You cannot log into the Arlo base station. The SSID cannot be changed and is broadcasted to allow only Arlo Wire-Free cameras to sync to it.
Two people can have access to the same base station/account by utilizing the Grant Access feature. In this way, the primary user grants a secondary user access to the cameras on the primary account.
1st issue understood. "Why I cannot log on".
Just a bit more clarification on the 2nd issue.
So if I set up the account on my mobile download the app etc... can't set up a end account on a pc. The second account being completely seperate from the 1st.
ginnsinn wrote:
Thanks James.
You don't need a second account for any device. The master account works on any device. The use of Grant Access allows another person to connect uniquely, again on any device. That allows you to share access to the videos and, optionally, the system (admin rights) without compromising the master account login details. An added benefit is that the second account won't kick off the first user as will happen when using the master account.
