Arlo wireless (H7) needs an option to set download directory path
  • 2 Replies
  • 2708 Views
Cameo
Right now the only directory that can be used is the Download folder. There should be a way to change that by the user.
manfredz
Hero
Hero
If you select SAVE AS  instead of SAVE you can have it download whereever you want to.
Cameo
The SAVE AS option does not exist on Android app. I only see it in the Windows PC app.
