Arlo security system indoor oudoor night vvision
  • 1 Reply
  • 3112 Views
alliejm1
I just purchased and installed "Arlo Security System - 2 Wire-Free HD Cameras, Indoor/Outdoor, Night Vision (VMS3230) "  i put them on the inside of my windows looking out and they worked perfect during the day and you can see clearly through the window and it detected motion.  now night time came and the infared went on but it is pitch black on the video and you cannot see thru the window.  any suggestions or way that it can see at night thru window....i tried changing some settings but do not want to mess up anything???
First , the Arlo cameras ( arlo and Pro ) will NOT sense motion thru the glass.
Second, at night with the glass , if the IR illuminators are turned on the IR reflects and washes out the picture.
So go to settings and toggle off the Night Vision ( use external lighting if keeping in the window )
OR
Move them out side where the should be
