Owned my system for several years. Always replaced them about every 6 months. Since the latest firmware update the battery life has gone to about 10 days. Cameras also won’t stay connected to hub even after I remove and replace batteries. Anyone having this issue or know the fix?
If you're having problems after that, don't hesitate to contact the support team so they can help you: Arlo Support
Hey Westmandon00,
Have you tried to reboot your Base Station? Try to move your Arlo Wire-Free camera closer to your Base Station as a test to see if that helps stay connected and if the battery life improves as well.
