  • 1329 Views
Westmandon00
Owned my system for several years. Always replaced them about every 6 months. Since the latest firmware update the battery life has gone to about 10 days. Cameras also won’t stay connected to hub even after I remove and replace batteries. Anyone having this issue or know the fix?
JessicaP
If you're having problems after that, don't hesitate to contact the support team so they can help you: Arlo Support
JessicaP
Hey Westmandon00,
Have you tried to reboot your Base Station? Try to move your Arlo Wire-Free camera closer to your Base Station as a test to see if that helps stay connected and if the battery life improves as well.
Westmandon00
I’ve tried all of that. From the other posts in this forum this appears to be an issue with Arlo and the latest firmware update. I read that they are working on a fix but I may not be able to wait for that as my security is more important than a software glitch.
JessicaP
