Arlo when I go to the library to view there is nothing recorded or showing up
  • 4 Replies
  • 3987 Views
ltepolt
I receive notifications of motion detected and have the settings as when motion is detected to record for 30 seconds.   The connectivity with the station is good but when I go to the library to view there is nothing recorded or showing up.  Why?
There have been issues every now and then re the videos coming a bit later then the alerts...server issue?
ltepolt
That I would agree with but the notification was issued at 2:11 am to my phone. I looked for the recording in the library at 5:45 am....
got nothing other than since your on a phone, un-install and re-install the app...
(btw, have you checked on a computer to see if in library there ?  at  https://arlo.netgear.com/     )
OR fire off a messg to Netgear Support to see if they have a better answer.   https://www.arlo.com/en-us/support/contact.aspx
ltepolt,
Consider a base station reboot using the on-off button. Allow the base station to come back online and test, do you see the same behavior?
