Arlo vms3230 has red tint. Tried pulling batteries and sync multiple times.
One of my cameras has a red tint. Pulled batteries and synced mutiple times, same result.
Yea join the club.... mine tints and then randomly stops. Really frustrating
A common issue with the older Arlo hd cameras....the ir filter is stuck.
If less than a yr, you have warranty ... if more than a yr, it’s a self fix.
tips;
pull batteries to reset , test
gently tap on hard surface to see if you can free it
use strong magnet on side to free it
do a search for more solutions ... red or pink color when viewing
