Arlo vm53230c light on my router is orange
  • 2867 Views
Daddysmell
I have it connect to my router but the light on my router is orange like something is wrong between the router and Base Station
The connection between the base and router is 100Mb/s so the orange/amber router lED is appropriate.  You don't need faster since the amount of data possibly sent between the devices is much less than that.
Daddysmell
So Should I purchase a better router or wifi extender? With all that I have running on Wifi?
Guess I don't understand your issue.  You say that your ROUTER LED is orange and I replied that it's indicating the speed of the Ethernet connection.  If you really mean that your BASE Internet LED is amber, that's different.  That means your base is connected to your router fine but the router is somehow blocking access to the Arlo servers.  That can be for a variety of reasons but first try turning off/unplugging your modem, router and base.  Then turn them back on, in that order, waiting for each to finish booting before going to the next device.  Is the base Internet LED still amber or is it now green?
