Arlo to Almond 2015 router
  • 2 Replies
  • 3024 Views
mav156
Hi
I have a arlo camera outside with wifi signal very low. I cannot move the netgear base station so what i do have half way is a Almond 2015 extender which works great for my other devices but my arlo camera doesnt connect to the almond extender.
Can i connect it to this extender ? if so how do i do that?
Also what is the range for motion detection?
mav156
HI
It worked connecting the base station upto the extender. Signal strengh full. Many Thanks
mav156 wrote:
Hi
You can't use an extender to give the camera more range... the camera links only to the BASE.
BUT, either one of two ways if your extender has an ethernet port is 1) center locate the base using the extender port 2) add a second base somewhere closer to the weak sig camera
Motion detection for people is about 20 ft max
mav156
HI
