Arlo stopped working!
  • 3788 Views
Warrezz1
I have 2 Arlo cameras with the base station. Both cameras have worked flawlessly for 4 months. I moved and deleted my cameras from the base station and then attempted to paired them back to the station and all of a sudden one camera will no longer pair to the base station. The green light blinks non stop but it will not pair. The cameras are only 4 months old! One camera continues to work great. Any help would be appreciated! Thank you! Dave...
steve_t
Master Master
Which green light flashes?
Open the battery doors and then reclose
( you say the cameras were rmoved already )
re- sync again BUT QUICKLY PUSH the base sync button, do not hold , then a couple secs later push the camera sync button.
If the above fails, do a reset of the base ( hold base reset for 10 secs till the front leds flash ) and re-do above.
Warrezz1
As the camera is facing me, it is the bottom right blue light blinking.
