Arlo sinc problems
  • 2 Replies
  • 3059 Views
KSelby
Im adding 2 more arlo cameras to my system.  They wont sinc up they just continue to flash blue.  any suggestions?
brh
@KSelby
The flashing blue light on the camera simply means that it is powered up if it is flashing rapidly.. Here is an article on the proper way to add cameras to your system.
https://kb.arlo.com/000039094/My-camera-will-not-sync-with-the-base-station-how-can-I-troubleshoot-i...
Couple of notes. On the base station you do not need to hold the sync button for two seconds. Just give it a quick press and the third LED on the base unit should start flashing green. Then follow the instructions.
If that doesn't fix it, contact Customer Support at the green banner near the bottom of this page.
Brian
steve_t
Master Master
I had the same problem a while ago and it turned out to be interference from my wifi router. I moved the Arlo base station a couple feet further away and it fixed it. Otherwise have done the same. Support has had over users restart their router and then the base and that has allowed the cameras to sync. Give those a go
