Just ordered 2 arlo cameras from amazon. Just wondering if it is possible to set them so they only are active at night. Live on a farm and have lots of farm equipment in and out and don't want that triggering them all the time. We've had problems with prowlers at night and would like to only have cameras on then.
Thanks!
Yes. Set up a schedule eg ARMED from 6pm-midnight and midnight-6am each day (or whatever you want) and disarmed during the day. Then set the system into schedule mode and it will run the way you set it
PS. If you are predominantly using the system for night use, I recommend the Arlo Pro cameras as being significantly better in low light compared to the original Arlo wirefree cameras
Thank You!
