Any plans to fix this Arlo? Have switched your system to a place with little security risk because of how terrible it is and now use Xiaomi for areas I care more about...better image with only 2K vs yiur pretend 4K, everything works the way it is designed to and 1/10th of the price.
That said I would like basic functionality to work please, have tried on 3x different devices and it keeps failing to reliably get location data for geofencing in the app.
Please provide a contact for your lawyers, in the case of loss to me as a result of your system not working I would like to expedite legal proceedings.
Kind regards
Remember that the Arlo app has to rely on the phone's location capability - the app doesn't do it by itself. Make sure the phone's location settings are enabled and set to allow the app to use them all the time.
