Hi,
I have been trying to set-up Arlo to work via IFTTT and switch on a LIFX light. It does not work. Arlo is working fine on its own. I can get other recipes to trigger the LIFX light. However, even if I try a simple recipe such as 'On Arlo motion send an email' it does not work.
Any help or advice much appreciated!
T23
tekton23,
If you check the IFTTT activity log does it indicate that the recipe attempted to trigger? What does it show?
Thanks for your reply.
If I check the log it just states that the applet was created. There are no further logs after that.
In the information it says:
- created 2 days ago
- Never run
If I 'Check Now' it responds and just says 'Checked'
T23
