  • 5 Replies
  • 3041 Views
kfox
I cannot view my video image at all on my arlo camera.  Appears to be conected in myarlo. It shows battery level and signal strength but no immage. It sometimes says camera is busy and return later.
5 REPLIES 5
App or browser? Did you try the other?  If using the browser, try a different one.  If app, try using WiFi or 3/4G instead.
kfox
I am using the browser. I don't have access to a device for apps at this moment. It now either states camera is busy or that I am only allowed 5 streams at once, please close one.  I only have one camera. I have tried to uninstall and reinstall the router and the camera but they may be residing in background as still installed from the time they were first installed.
Try resetting things by using the power switch on the base and open and close the battery door on the camera.
kfox
I've tried that. Now I cannot even reinstall the arlo router. How can I get to arlo support to get a trouble ticket?
Power cycling somehow removed the base from the system?  You can try a factory reset (deactivate the device in settings, use the reset button until the LEDs flash amber and start by adding the device in settings, resync cameras and rebuilding modes and schedules)
As always, click the Support link at the top right of these pages.  Look down a bit on the right of that page for the link to contact support.
